chipped p28 help
so what would be the bad about running a na d16 with i/h/e on a p28 ecu that is chipped for a turbo d16
mmmm well if its set up for a boost application, it's probably gonna be set up to run bigger injectors, which will be screw your A/F ratio up. Any if you're buying it, it's not worth the money. If you have it around, i'd see leave it alone. It's pointless in the first place, not to mention that if its tuned/a baesmap for a turbo setup, it's not gonna run **** right.
Just no. |
i dont have it lying aroung wanting to put it in my car, it already is, it came that way. my car seems to smell like burning gas alot and it misses at idle and stutters at acceleration sometimes so i was just thinking this might be the problem
wow, this is something else. Go get the right ecu for your engine code.
Originally Posted by nik005
(Post 597044)
the ecu is tuned to supply more fuel, and since you don't need that extra fuel, you're running rich
Originally Posted by ej6buddy
(Post 597054)
d16z6=p28 |
it is d16z6=p28 |
(Post 597185)
I'm sorry if I wasn't clear. I know that's the correct ecu he has. BUT, I meant get the actual ecu for the engine that's not altered by an embedded chip.
i get you now |
i took the ecu out and looked at it, and it is not chipped, but my car still runs bad, it misses at idle some, i know its not the timing cause i just did that a week ago, any suggestions
(Post 597238)
i didnt know if it was chipped or not, i just wanted to know what would happen if it was and i was driving it like that. but that is not the problem cause it isnt chipped and my car still misses sometimes at idle and now it stutters when i accelerate in 1st
