d15b2 to d15b
alright i swapped the engine went in no problem. im using the p28 ecu ive wired up the the mpfi but my injectors are not firing.fuels going through the rail.i used this conversion harness from xeno chrone i have no clue what the problem is
i have spark when i sprayed starter fluid in it and it stayed running for as long as i did.. i stayyed out all day trying to figure it out.do i need a four wire o2 sensor?? when i got the motor it came with a 1 wire.
maybe you do, however that would not effect fuel reaching the cylinders....
first i would test the wires to the inj's , and double check that you have the sequence correct..
what manifold do you have??? stock??
you've been holding outinfo..... i noticed that i replied to more than one post from you...
how did you go about the dpfi to mpfi conversion?? did you install a resistor box???? because you definately need one. dpfi all four wires from ecu go to inj's, 2 each.. mpfi is one wire per on inj from ecu, and the other four wires come from the resistor box, is this how you did it??
you know what ive been lookin and looking and from what i gathered from most these people that i didnt need one but your telling me i do need one.well do you know what ohm the resistor box is??no junk yard around here
