D16Y7 turbo ecu
If i would turbo my D16Y7 what ecu would you suggest? Its OBD2 so from what i hear its untunable and i dont want to spends thousands on systems like the AEM EMS, etc. What are some options?
RE: D16Y7 turbo ecu
odb1 conversion, then use something like hondata, crome, neptune, etc.
RE: D16Y7 turbo ecu
p06 OBD1 ECU i believe. I think the P28 is a VTEC ECU.
^ edited to correct, thanks Tyler |
RE: D16Y7 turbo ecu
p06 non vtec, p28 vtec. gotta get a obd conversion harness and someone to chip your ecu for you.
RE: D16Y7 turbo ecu
www.phearable.net
^ can get an OBD1 ECU, conversion harness, and a basemap all from one place (i've heard of cheaper places to get ECU's, i've never actaully seen one). |
RE: D16Y7 turbo ecu
ORIGINAL: aryiman98civic p06 non vtec, p28 vtec. gotta get a obd conversion harness and someone to chip your ecu for you. |
RE: D16Y7 turbo ecu
mxs suggested a P72 ecu...because you can retain your knock sensor....
RE: D16Y7 turbo ecu
Would this be what i need?
Chipped/Socketed NON-VTEC Phearable.net Ecu.+ Obd2 to obd1 conversion harnes for $230 |
RE: D16Y7 turbo ecu
^ sounds good to me
| All times are GMT -8. The time now is 10:44 PM. |
