dist. problem
Old Nov 1, 2006 | 11:11 PM
bigwill1384's Avatar
Default dist. problem
i have a 93 civic HB 1.5l non vtec and i bought a new cap and rotor and ive only had it for about 3 weeks now and theres allready corosion build up on the metal ***** inside the cap snd theres a decent amount? any input on what to do (besides clean it) or what might be wrong??? i have new NGK plugs, 9 mm wires and the cap and rotor is Gsport (mr gasket)
Old Nov 2, 2006 | 12:13 AM
Misha's Avatar
Default RE: dist. problem
Why did you replace original ones? And why not by OEM parts? I frankly don't know what is Gsport( or mr gasket for that matter)
Old Nov 2, 2006 | 02:10 AM
Pete's Avatar
Im guessing the cover doesnt fit properly? Clean it up and get an OEM....see if it persists.
Old Nov 2, 2006 | 12:17 PM
yea ill try getting a origanl one . Mr gasket is a brand
Old Nov 4, 2006 | 05:53 PM
MY99SI's Avatar
you really dont need an aftermarket ignition system, if you were going for power, the stock honda ignition sys. is known for up to about 400hp
Old Nov 4, 2006 | 07:34 PM
HARI.'s Avatar
ORIGINAL: MY99SI
he's not planning to get an aftermarket ignition system. he was asking why there's a corrosion build up on the metal inside the distributor cap, and it's a brand new cap n' rotor
98civex
Sep 19, 2010 04:50 AM
chriswf
27
Apr 3, 2010 03:49 PM
bigwill1384
Nov 13, 2006 10:22 PM
larsenracing
Mar 28, 2006 09:58 AM
joey
Nov 9, 2005 11:40 PM
