ect help?
Old May 10, 2013 | 10:50 AM
chitolocz's Avatar
Default ect help?
Hello everyone I have a 94 civic dx. I left a friend of mine replace my transmisson and when he did it was just a cluster ****. Most of the problems we were able to take care of but there is still one thing bothering me. The temp needle stays on cold and never moves. I did my reseach and wasn't able to come up with much. I found of that the sensor under the dizzy is the ect and I found mine and it's cut. I have three other wires that are cut and I'm so confused. Any help would be greatly appreciated
Posting pics in a sec.
Old May 10, 2013 | 11:20 AM
The 1-wire sensor under the distributor is the temp gauge sending unit. It has a Yel/Grn wire. Solder/shrink wrap that wire to its connector and plug it into the sensor. The gauge should then work again.
Old May 10, 2013 | 11:23 AM
chitolocz's Avatar
upload pictures online"]http://
upload pictures online[/URL]
The three coming from the harness
1. Yellow/green
2. Red/white
3. Green/white
The two from the sensor
1. Red/yellow
2. Green/blue
Old May 10, 2013 | 11:27 AM
The Red/Wht and Grn/Wht wires are for the 2-wire ECT sensor under the distributor. Solder/shrink wrap those wires to the matching wires of the sensor connector. This will make CEL code 6 go away and you'll get better mpg and a better idle.
Old May 10, 2013 | 11:30 AM
chitolocz's Avatar
Ok awesome so what do about the third wire?
Old May 10, 2013 | 11:31 AM
See my first post.
Old May 10, 2013 | 11:40 AM
chitolocz's Avatar
Ok well I wired the green/white red/wires to the ect sensor but now I have a crazy idle.. and for the one wire I have not the slightest clue where it does. Sorry for my inexperience :
Old May 10, 2013 | 11:43 AM
The 1-wire sending unit is located just rearward of the 2-wire ECT sensor under the distributor.
For the idle problem, start by resetting the ECU. If the idle doesn't improve after some driving, then clean the IACV and FITV, and bleed the cooling system.
cvcrcr99
Nov 8, 2011 07:04 AM
97_ex
May 4, 2007 08:45 AM
lowpros8
Nov 26, 2006 05:01 PM
dalifts
Sep 29, 2005 06:08 PM
dalifts
Sep 14, 2004 08:31 PM
