ecu?
Old Jan 5, 2005 | 11:23 AM
andryuha's Avatar
Default RE: ecu?
It's going to take a whole lot more mods than you have now to make your car go 200mph. That's like a top speed of a Diablo. WHy would you want to go that fast anyway? Even if you could make your car go that fast, you will most definately need new suspension and aerodynamic parts to make the car stable at those speeds.
Old Jan 5, 2005 | 02:58 PM
XCM828's Avatar
Default RE: ecu?
Not to mention that most places don't have 200 mph speed limits.
Old Jan 5, 2005 | 06:29 PM
andryuha's Avatar
Default RE: ecu?
ORIGINAL: XCM828
good point [sm=smiley32.gif]
Old Jan 5, 2005 | 08:01 PM
fast97's Avatar
Default RE: ecu?
yes your ar right. My car will never go that fast but if it could it would be prety sweet to say that you have a car that could do it if you want. the thing i want to know is does any body know where i can up grade my ecu to give me a little boost in power.
Old Jan 5, 2005 | 08:40 PM
XCM828's Avatar
Default RE: ecu?
WWW.HONDATA.COM
jeez how many times do i gotta tell you....
Old Jan 5, 2005 | 08:52 PM
fast97's Avatar
Default RE: ecu?
They dont list any thing for the D16y sieries motor at all thank for the input though sory did not see that hondata until now.
Old Jan 5, 2005 | 08:58 PM
XCM828's Avatar
Default RE: ecu?
ah didnt see what engine you had. Here's a list on their site for other ecu's thatll fit on ur car, http://www.hondata.com/vehicles.html. You could find another ecu that hondata has systems compatible with, then swap it in. http://www.hondata.com/ecus.html
Old Jan 8, 2005 | 07:40 PM
fast97's Avatar
Default RE: ecu?
Well how about this do you think that i can put a EX ecu into my 97 HX without any problems?
Old Jan 8, 2005 | 08:35 PM
sacicons's Avatar
Default RE: ecu?
it wont run right. the VTEC systems are different, and it will kick the cam over at a higher rpm, READ:slow as hell, no low end power. just so you know, the weak point of your car is not the ecu. you may get a couple of HP out of it, but its not the best place to start. your car has what? 117hp to start with? get it up to about 135, then get into the electronics of it. till then, the gains from the ecu will be minimal.
Old Jan 8, 2005 | 08:44 PM
fast97's Avatar
Default RE: ecu?
I should be close to 135 hp. I have header, catback exhaust, msd cap coil, msd wires, cold air intake and high flow cat. You think it would run though? Cause like i said it has two cam profiles on the intake side.
