electrical problem
Old Oct 6, 2006 | 11:54 PM
bigwill1384's Avatar
Default electrical problem
i think i have a problem with my elctrical system in my 93 honda civic HB(1.5l) the only time i notice this is at night while the headlights are on only when i first start the car up i turn the headlights on and when i turn the turning signal on the dash,and heater lights flicker usaly its hard to notice it b/c it happens quik but it did it tonight and the lights flickered for like a second??? any tips or help would be apreciated!
Old Oct 21, 2006 | 01:02 PM
intense_gravity's Avatar
Default RE: electrical problem
go to your fuse box inside your car under the steering wheel and check to see if all the fuses in there are correctly ... if its a 1.7 fuse put in a 1.7 fuse.. dont go higher.. had that problem before... you should have a fuse detail print on the back of the cover
Sporange
15
Jan 12, 2007 01:07 PM
93HBEX
Jun 16, 2005 01:45 PM
civicgolg
May 24, 2005 04:13 PM
thirddensity
Jan 31, 2005 03:19 PM
Norman_x
Dec 8, 2004 02:09 PM
