Fuel Level Gauge
I hope I'm in the right place to post this, but here I go...
After installing my reverse glow gauges my fuel level gauge seized working. I'm guessing that is because I have moved it a little while the installation. Has anyone had similar issues? Does anyone have any idea how to fix this? |
RE: Fuel Level Gauge
did u check your fuses?
It's stuck on full. I'm not sure that a fuse would cause such a problem, but will check into it.
is it rubbing on the new gauge face?
It isn't rubbing...triple checked that. It stoped moving completely after I moved it a few degrees putting the faces on and that's where they've stopped working. All of the other gauges work allright.
u might have a short. check the wires.
