fuel pressure reg install
Old Nov 15, 2006 | 02:17 PM
97civicturbo's Avatar
Default fuel pressure reg install
hEY all, just installed an adjustable fuel pressure reg on the civic. first time i fired her up she was trying to die on me. I wasn't completely sure I had knew which was inlet, which was outlet for the fuel on the regulator so i switched them and fired her up again. This time it cranked but wouldn't start, so I figured I had it correct the first time and maybe the pressure is just set too low. So i switched them back to where I had them the first time and now nothing will happen, just cranks. Could I have broken the FPR by hooking it up wrong or couil there be another problem I'm not aware of. This seemed to be a pretty simple install and I'm kinda pissed its giving me trouble. Thanks in advance.
Old Nov 15, 2006 | 02:24 PM
HARI.'s Avatar
Default RE: fuel pressure reg install
you need to set the pressure to 40psi. the engine has to be running. unhook the vacuum hose that is connected to it and adjust it. you also need the fuel pressure gauge so you know where the pressure is at.
Old Nov 15, 2006 | 03:09 PM
yeah pressure is set at 40 but the car won't start that is my problem
Old Nov 16, 2006 | 08:16 AM
What kind of FPR did you get? I've heard the cheaper ones can do more harm than good
Old Nov 20, 2006 | 04:19 PM
yeah its a cheap one off ebay. its acting like its not getting fuel but when one end is unkooked and you turn the key fuel runs through and comes out the other end. im stumped.
Old Nov 21, 2006 | 01:36 PM
riceburner700's Avatar
i would ditch the cheap on and go with like a aem or like a b&m
Old Nov 23, 2006 | 01:31 PM
put the stocker back on and still wont start. Do you have to do anything special like bleading the line of anything when you do this?
Old Nov 25, 2006 | 05:25 PM
civtec00's Avatar
if the fuel lines are hooked up right, you might have a clogged line. is fule getting to the regulator, and the injectors
Old Nov 25, 2006 | 08:34 PM
MY99SI's Avatar
check the filter.... lol but did you unhook anything else like the battery terminal? or did u swap out anyother parts at the same time?
Old Nov 26, 2006 | 06:36 PM
no other parts were swapped, filter is brand new, and yes the battery was disconnected during install.............
