fuel pump location????
Old Jul 21, 2007 | 10:14 PM
pershingzeta4life's Avatar
Default fuel pump location????
I have a 92 Honda civic and i need to change the fuel pump but i dont know where it is located at and how to get to it. Any info is greatly appreciated.
Old Jul 21, 2007 | 10:57 PM
BlackEM1's Avatar
Member
Default RE: fuel pump location????
It's in the gas tank. I think you have to pull the backseat out to get to it, but don't quote me on that.
Old Jul 23, 2007 | 04:59 AM
cpl rampage's Avatar
Thats right, feel along the middle of the back seat, between the bottom and top peices, there is one bolt there, i think it is a 12 or 14 mm, undo that and the whole bottom of the seat will slide foward / lift up, and you can then remove it from the car. from there you can see a roundish cover, held on by 4 or 5 bolts undo that and tou should be able to see the gas tank, then just unbolt the fuel pump/fuel sender assembly and pull it out of the tank, make sure you do this outside and away from sparks. you may also want to releive the pressure in the tank by opeing the gass cap, as well as removeing the bleader valve on the fuel filter under the hood.
Old Aug 12, 2007 | 11:06 AM
Thanks guys. I appreciate the help. It was very useful.
EarleH
Jun 25, 2015 08:14 AM
ktorres1120
Sep 4, 2013 08:07 PM
joshh44
Nov 23, 2007 07:22 AM
seriously_furious
Aug 14, 2006 08:49 PM
superfestiva
13
May 26, 2006 04:20 PM
