How do you install a fuel pressure regulator?
Old Feb 6, 2007 | 11:32 PM
TIcivic00's Avatar
Default How do you install a fuel pressure regulator?
I bought a JDM Fuel Pressure Regulator for my 2000 Civic Ex D16Y8. I was wondering if anyone can give me complete step-by-step directions on how to install this?
Old Feb 7, 2007 | 05:57 AM
Street Sniper's Avatar
Default RE: How do you install a fuel pressure regulator?
It's a fairly simple affair, but to be safe, go get a Hayne's or other shop manual of your choice. Otherwise... relieve the fuel pressure and it's like two hex bolts and a little hose. Good luck.
Old Feb 7, 2007 | 09:29 AM
The only tip I have is to sell that "jdm" fuel pressure regulator. If you really want an FPR spend the money for a nice one, or you'll end up regretting it down the road
Old Feb 7, 2007 | 11:35 AM
TIcivic00's Avatar
What type of FPR would you recommend that I get?
Old Feb 7, 2007 | 11:44 AM
aeromotive is a good name. You could go with a B&M, but I've heard even those aren't the best.
What's your current motor setup?
Old Feb 7, 2007 | 02:01 PM
TIcivic00's Avatar
d16y8 with dc header, skunk2 i/m and 68mm throttle body, and short ram intake
Old Feb 7, 2007 | 04:55 PM
INJENalltheway's Avatar
For installation:
Relieve Fuel Pressure- Unscrew gas cap
Detatch Negative Battery Terminal- On battery lol
Take off the fuel hose and the vacuum hose from the FPR
Unscrew Mounting Bolts
Remove Regulator
Install New Regulator- Installation is reverse of removal
Use a new O-ring- Make sure to put a light coat of CLEAN oil on the ring [sm=yeahsmile.gif]
Check for fuel leaks!!!
STRAIGHT OUT OF HAYNES ***** FUGGA!!
Old Feb 7, 2007 | 08:11 PM
riceburner700's Avatar
go with like a b&m or like an aem yeah they are pricy but nice
Old Feb 7, 2007 | 08:30 PM
TIcivic00's Avatar
Alright thanks, What does anyone sugest for fuel injectors? I was looking at getting Venom.
Old Feb 7, 2007 | 11:19 PM
unless you are running some stage 3 cams and some extensive modding like forced induction your stock injectors will do just fine
