Idle
ORIGINAL: MY99SI
i wouldnt complain if it was doin that jus fine.
but theres an idle adjustment screw on the throttle body that you can turn and adjust the idle speed
Paperclip in the jumper by the ecu
Pull the plug on the IACV
Start car (will probably run crappy)
Adjust Idle screw until RPMs reach ~450
Shut off car
Plug in IACV
Pull paper clip out of jumper
Start car, should idle around ~650ish
keep in mind this is for 92-00 SOHC vtec motors, numbers will vary for DOHC, non-vtec, etc
honvic
Sep 2, 2011 09:49 PM
JBaris
Nov 22, 2010 03:56 PM
tsh30039
Sep 30, 2006 02:45 AM
green1996civic
Jun 14, 2004 06:26 PM
