intgegra ls swap to a 98 ex
Im new to the whole honda seen and trying to gain some info. I just bought a 98 ex 2dr 5speed. I previously had an integra that got rear ended and the motor and trans is still good it was all stock except I was told it had a 2.0 L port n polished head off a crv. My question is would it be worth it and how difficult would it be to make the swap? I not trying to build something fast just a little more power. Any help or knowledge would be greatly appreciated thanx Shawn,
Its a simlpel swap. You need a 99 Civic Si rear trans bracket, 99 Si "timing belt side" mount bracket, 99 Si AC bracket (if you want to keep AC), 99 Si power steering hose, 94-01 Integra Ls throttle cable, the OBD1 P75 ECU for the B18b1 OBD1 along with a OBD2 to OBD1 jumper, 99 Si or 94-01 Integra shift linkage. Thats about it, use the Ex engine harness it will all plug in just fine, you may need to extend some plugs on the harness to reach.
