Kill switch installation
can any one give me a DIY on installing a Kill switch. i installed one but when it is off every time i turn it on i have to reset my clock and my radio stations. is there a way to install it so i won't have to do this.
RE: Kill switch installation
Are you talking about an ignition cutoff switch or a battery disconnect?
the one i have it is connected to the battery. but to me it does not matter as long as the car wont start when it is off and i dont have to reset the clock and the radio
the one i have now is connected to the battery. it does not matter to me what it is connected to as long as the car does not start when it is off and i dont have to reset the the radio or clock
I'm not sure I understand, why would your car start if it's off?
There is either a kill switch or a battery disconnect... many forms of organized racing require one or the other. A battery switch requires running battery cables into the passenger compartment and mounting a cutoff lever. A kill switch is a simple switch that kills the ignition (but still lets power get to everything else) and is attached to the coil solenoid. |
If you connected it to the battery then you wired it all wrong. If you hook it up to the battery, then every time you activate the kill switch all the presets are gonna go as well as the long term fuel trim for you fuel maps. Every time you activate the kill switch imaging you are removing the battery from the car, because its pretty much the same thing. This is a very idea for several reason. When i wired a kill switch for my buddy, i cut the power wire for the fuel pump and wired the switch into that. You can also use the ignition or a couple other wires. I dunno how you even wired a switch into the battery since the cables are pretty damn thick.
