map sensor help please
ok guys i am new to the honda camp and i am in the middle of boosting a d15b7 in a 93 dx coupe and my question is , what map sensor do i use for boost , i know in my celica i was able to put in a few check valves so the map would not read boost and that worked for around 14psi but i then went with a 3 bar map sensor to run more and i did not have to use the check valve trick , but the honda map i have is on the throttle body so i dont think the check valves will work as there is no vaccum lines . i dont plan on running alot of boost (8-10psi) as this is my wifes car and she just wants it to keep up a little better on the streets
, the kit i put together so far has ( a t3 48 trim turbo, fmic,a 12:1 fmu, type s bov, 38mm tail wastegate at 8psi spring, 2 1/2 ic pipes & down pipe , 2 1/2 exhaust with high flow cat and a dtm otto racing muffler, ss tube manifold) , and i will be installing a apexi safcII when i get it out of my celica. we dont plan on big numbers (170-190hp) as i dont want to hurt the motor to much , the fuel pump was upgraded to a walbros 255 that i had left over from my celica. so if you guys could help me out this would be great . thannks mugen93
ok after a little research i was able to answer my own question , ( the missing link unit) sorry for the rookie question, and if any one has any help with the kit i am putting together please let me know thanks again
If you get a tuned ecu you won't have to worry with stop-gaps like a missing link. I don't think you are gonna be happy with that fmu.
ps- I would say 170-190hp on a b7 is pretty optimistic, and you definitely dont' want to go more than 8 psi on a stock motor. Probably more like 6-7 on a fmu.
yeah i know the fmu is not the best but once i get my emanage tuned in my celica i will put my safcII in and run a set or rc injectors i picked up from a buddy , i think they are around 340cc i think so i will toss the fmu , at start i will only run around 3-5psi as the wastegate spring i have in is for 3.8psi , as far as hp i really dont care what i get just as long as it is better than stock because this ride is very slow
ok i would like to know what is the weak points of the d15b7 motor so i have a idea what to look for down the road , and upgrade , i dont want to swap i know it would be more power but i like to be differant, and i have 3 d15b7 motors around so i would like to put them to use
ok i have came across a good deal on forged pistons for the d15 ,now my question is where do i finr con rods for it or do i have to worry about it some say the stock rods can take 200+ hp but i dont know they seem very small, i also will be having the head p&p , i know someone at a performance shop that said he would do it to help me out ,what a bud
, now i dont want to run a 10 sec car but i am shooting for a very reliable build so any help would be great
on my d16z6 i had the fmu missinglink set up any thing more than 6psi my car would lean out even at like 4.5 to 5 psi on the highway if i would drop a gear and try to go i would lean out for about 2 seconds or so then the car would take off back to normal other wise i could floor it from a dead stop threw all gears with no problem but if i was to drop a gear i would have problems. only thing i did not like about my kit was if i was doing a fifth gear put the egt's would rise extreamly fast.
