NEED HELP>>>WILL PAY
Old Apr 7, 2008 | 06:47 PM
TDOTZFINEST's Avatar
Default NEED HELP>>>WILL PAY
Installed AEM intake in 2006 civic ex and now its been a few months and the engine light appears and disappears. Someone told me that i should retune it to the new intake. I brought it into the dealer just to see what they would say and they gave an explanationof something like to much air , fuel ratio.... I am not a mechanic nor have the knowledge to understand...if someone here that lives in GTA area Toronto,Ontario i will pay someone to retune my car with the new intake...or if anyone else has any suggestions.
p.s. i have checked all seals and the chip on the intake, it's fine.
your help is appreciated.
Old Apr 7, 2008 | 06:53 PM
macbeth18288's Avatar
Default RE: NEED HELP>>>WILL PAY
chip?
Check the seal on the o2 sensor
sometimes that can throw a CEL
That kind of sounds like what it is since it "appears and disappears"
Old Apr 7, 2008 | 07:01 PM
FlipHKD720's Avatar
IAT sensor man*, not o2 ^
did you reset your ECU? (disconnect your negative battery terminal for 5 minutes)
Old Apr 7, 2008 | 07:22 PM
IAT sensor..should i try to remove it and reisntall it wilth some type of seal??? I did the battery thing no luck . There is only 1 sensor on it right?? Its pretty tight,, but there is no form of seal around it ...should there be??
Thanks guys for your quick response.
Old Apr 7, 2008 | 07:31 PM
IAT or IAN flip?
Old Apr 7, 2008 | 08:02 PM
FlipHKD720's Avatar
intake air temperature, i once called it an o2 sensor as well but MXS corrected me with the IAT.
Old Apr 7, 2008 | 09:31 PM
OK I gotcha.
It's just on the other post you had put IAN and I got really confused then, haha.
THanks for the info.
NonTurbo4now22
Oct 31, 2006 04:44 PM
cowsgonemadd3
Jul 10, 2006 06:34 PM
yerryjusko
Jun 28, 2006 11:20 AM
JohnHenry
Jan 26, 2005 02:40 AM
White_Devil
Dec 5, 2004 03:04 PM
