noob ?, please help
Old Jul 6, 2006 | 08:50 PM
theonecalledtodd's Avatar
Default noob ?, please help
hey yall, ok, i think this is the right place to post this.
I just installed an aftermarket exhaust (magnaflow) and im pleased with it, BUT the check engine light stays on at all times. Now, i know why its on because i already got it checked (something about a cataltic problem) which makes since because i got rid of the converter all together, SHHHH. What i need to know, is if theres any way to stop the engine light from coming on because of this problem only. If theres any way to change the computer to not recognize just this as a problem, then please let me know, thanx
Old Jul 7, 2006 | 08:19 AM
Default RE: noob ?, please help
come on guys, please help, lol
Old Jul 7, 2006 | 10:55 AM
sillyredcivic's Avatar
You can do an O2 simulator, or you can do a resistor in line with the sensor. I don't remember what resistance you need to feed it though, and why would you remove your cat? There are no major gains by doing so except for sound unless you have some major work done. Eh, anyway, thats what you need to do.
Old Jul 7, 2006 | 11:21 AM
My04Civic's Avatar
Administrator
i would try and just unplug the battery for a second, it should reset it, and if i remember correctly, i think i saw someone on here say you can take out the ecu fuse (under hood) and plug that back in and it should reset it, let me know how you make out!
Old Jul 7, 2006 | 01:23 PM
jwsimons's Avatar
if you did not use the special socket you most likely broke the wire at the cap.on your o2 sensor. but try a reset first, just in case
Old Jul 7, 2006 | 09:28 PM
ok, i reset the check engine light thing, and it came back on after a little bit, so what are my options now to stop it from being on (the light doesnt bother me, its just that i know that the cat. is the problem, but what happens when i get a real problem, ill never know)
Drdslove
Jun 3, 2009 08:12 PM
bichslappa
Oct 22, 2007 06:24 PM
kaminar
Jun 6, 2006 11:25 AM
jonyg98civicex
Jan 7, 2006 03:19 PM
V
Aug 16, 2005 04:43 PM
