o2 sensor
Old Jan 9, 2005 | 12:30 PM
jwsimons's Avatar
Default o2 sensor
recently my check engine light went off (lighted up) so i pulled down the carpet , 1 blink, dbl check book, and yes its the oxygen sesor, so i replaced it, light went out for about 10 minutes and then its back, this happens everytime i drive the car now . after about 10 min's chck engine comes on , ecu blinks `1 time. any body got any hints , clue's, homeopathic remidies? i'm open to suggestions. thanx
jonathan
Old Jan 23, 2005 | 09:20 PM
red_sleeper's Avatar
Default RE: o2 sensor
did you reset the ECU? you do this by going to the fuse panel under the hood(atleast on mine 99 civic) theres a fuse called back up its a 7.5 pull it for 10 secs. resets the ecu and clears the code. or go to autozone have them run the obd controller on it and clear the code. hope that helps
Old Jan 26, 2005 | 06:56 PM
fast97's Avatar
ORIGINAL: red_sleeper
Or just disconect the battery much easiery if you ask me.
Old Jan 26, 2005 | 10:49 PM
Kappa22's Avatar
I love having an ECU coder...
addiction2bass
Aug 14, 2008 09:53 PM
fglaustin
Mar 27, 2008 08:29 PM
vtec02
May 9, 2007 05:17 AM
00sithrottle
May 12, 2005 10:25 AM
