obd2a to obd1 problem
hi, everyone, i have a 96 civic si, p2t ecu, just bought a obd2a to obd1 conversion harness, putted in a P30 ecu and the car starts up just fine, except it gives me the 22 error, vtec pressure switch, i have no vtec at all.. can anyone tell me what is the problem? i've checked the conversion harness and it seems like no problem.[/align][/align]thanks.[/align]
RE: obd2a to obd1 problem
isn't P30 for a B16a2, which is VTEC and OBD2? Where did you get your ECU from?
ORIGINAL: FlipHKD720 isn't P30 for a B16a2, which is VTEC and OBD2? Where did you get your ECU from? |
ahhh aright, Civic VTi in Europe right? Well that seems odd, they're both B16a2 ECU's, just differnt OBD's. I'll stop posting though because i dont know any farhter than that haha sorry i couldnt help more
ORIGINAL: FlipHKD720 ahhh aright, Civic VTi in Europe right? Well that seems odd, they're both B16a2 ECU's, just differnt OBD's. I'll stop posting though because i dont know any farhter than that haha sorry i couldnt help more |
hi,[/align]just found out what i have to do, on a b16 engine there are 2 vtec sensors, one opening the vtec oil pressure valve, and another that reads that vtec oil pressure, if there is no oil pressure on the vtec circuit, it won't engage! so.. all i have to do isshunt wire A4 with D6 inside the P30 ecu.[/align][/align]hope this helps anyone![/align][/align]thanks![/align]
Glad you figured it out, I was going to say that some VTEC engines from overseas don't have the pressure switch.
ORIGINAL: mxs Glad you figured it out, I was going to say that some VTEC engines from overseas don't have the pressure switch. heated up the screw driverand melted some welding tin onthe pins in the ecu i wanted to weld.. :p[/align]turned out to be very cool.. :p[/align]this is how it turned.. :p[/align][/align][/align]http://img78.imageshack.us/img78/8251/12122007dm5.jpg[/align][/align]just tried the ecu and it works real fine! :p[/align]seems like i going back home on weekend with a new ecu and vtec all the way!!! :D[/align][/align]c ya soon![/align][/align][/align][/align][/align] |
| All times are GMT -8. The time now is 06:55 AM. |
