pr3 trouble
Old Aug 14, 2006 | 11:01 PM
turbob18c1's Avatar
Default pr3 trouble
swapped a b16a obdo into a 91 ls and the pr3 ecu keeps throwing the number 7 code, which is the tps code, but the problem is im getting 5 volts to the 2 power wires (the 2 outter pins) whichs is normal and the more i open the throttle the more voltage the center wire gets, which is normal as well. i have no clue wft to do, has anyone esle had this problem before? ive unplugged the ecu and swapped tps sensors, please help
Old Aug 24, 2006 | 03:54 PM
jwsimons's Avatar
Default RE: pr3 trouble
you need to swap the bottom and top wires, yellow/ white and gree/white if i remember correctly. basicallythe tps is upside down.
Old Aug 24, 2006 | 04:18 PM
Marty's Avatar
you are supposed to get .5 volts at closed throttle and 4.5 at wide open throttle.
mycivic
Jan 18, 2007 09:55 AM
turbob18c1
Apr 7, 2006 07:34 PM
jwsimons
Jan 27, 2006 05:05 AM
smokingemcee
Jan 24, 2006 08:21 PM
