Trying to get unplugged plugs plugged in...
Okay I have a few plugs not plugged in around my bay and im trying to get this ish situated so I can find my secondary 02 sensor wire to hook it up down to the cat... and remove my CEL
Yeah its the purge control ish thing.... but I have to purge solenoid....
as both you and 94cheezeburger have told me I will most ilkely need a new obd1 IM but I have no money for that right now so im just tryiing to hook up anything I can..
That is a GSR intake manifold. I do not believe that is what he needs.
That is definitely an O2 sensor harness, I can tell by the distinguished shape of the plugs.
However, if you are OBD1 then you don't need the sensor at all. I would take the O2 sensor out of the cat and replace it with an O2 bung plug (a short bolt), and take the wire harness and zip tie it out of the way or even just cut it off where it comes out of the engine harness loom since you will never need it.
simons81
04-25-2012 12:10 PM
burnindesirez02
02-17-2010 10:35 AM
b16Ek4
06-20-2005 10:59 PM
