turning an AT ECU to a MT ECU-Is it possible??
I found this http://www.fast-track.5u.com/diy%20at%20to%20mt.html but because of the language i cannot understand what exactly i should do...
Is there someone that knows how you convert an AT ECU to a MT ECU??
Thanks
Thanks
I have the JDM P08 one....
So the only thing i have to do it is to replace the RP18 one lowered in value from 2.4k to 1.4k ohms??
If yes which one is RP18??
Thanks again
I think that R18 on your JDM ECU is somewhere in the circled area in this picture. (it will be labeled on the circuit board)
Thanks once again !!!!I thought that i had to remove both of them(like the MT looks like) but i did it and it doesn't work
So i have to put them back and replace the one that i should
Thanks again and i will come back when it is done...
.So i have to put them back and replace the one that i should
.Thanks again and i will come back when it is done...
I hope that too
Also the AT ECU that i have know it is empty at the ROM plac but i found one on Ebay that it is JDM AT ECU non-chipped with a chip on the ROM place...Do you know the differences if they are any??
.Also the AT ECU that i have know it is empty at the ROM plac but i found one on Ebay that it is JDM AT ECU non-chipped with a chip on the ROM place...Do you know the differences if they are any??
