Very weird electrical problem. Starter dead, noises, other random crap...help needed asap
Make sure all your battery connections are clean then. If it happens again, take your battery to get tested. If the battery turns out to be okay, get your electrical system checked.
It's worth it because there's not much worse than being on the road and have an electrical problem that you can't trouble shoot. Especially when your girl is sittin beside you lookin all sexy and you're on your way home with her!
ORIGINAL: ngoti8tor
try to jump start it... if you can. its deffinatly the battery. you might also have a dirty connection. after awile build up from the transfer gets too much and gets in the way. its easy to clean with a hard brittle brush.
I clean battery posts every time I change my oil...and I swapped out the battery for the one from my van and it's still doing the same thing...and the van starts fine
MrFirewolf1000
Mar 28, 2012 03:40 AM
bucklebabe
Aug 24, 2011 09:23 PM
tyke
Oct 13, 2007 11:02 AM
