What are the best starting modifications for a 1992 Civic Hatchback(165,000km)
My name is Dan. I am 17 and live in Mission B.C.... I have a 1992 Honda Civic Hatchback with only 165,000 km. I am starting to make good money now, and have decided to put some modifacations on the motor.... The only problem is I have no idea what would be best for the car and the motor. I am looking to add 30-60 hp and any sugestions would help alot.... Thanks
Dan[8D]
Dan[8D]
first of all do suspension. Some lowering springs and some wheels to start things off ftw. Then if you wanna do some major modifications, start saving for a turbo project, or if you wanna do something basic, get a nice I/H/E setup
you should start with ACL bearings. They sell a racing bearing set that sells for 99 bucks, they are gold, after installing these bearings the skies the limit for your motor
30-60 HP? You can get around 15-20 HP with I/H/E thats being generous, you can prolly reach 35-40 HP with cams and tune. Anymore then that your gonna need head work if you wanna keep it N/A. If your looking for more above that turbo it.
I/H/E, cam, intake mani, and a tune. Should do you pretty good, By chance is your car a Canadian CX? If it is you'll want a different throttle body, pick up a 95 civicLX throttle body,and probably a P06 ECU.
