Wireing harness questions
Old Feb 27, 2007 | 12:51 AM
LarsonSi_0091's Avatar
Default Wireing harness questions
i have a 91 crx si that has a d16a6 and im swapping a d16z6 into. So what am i gonna have to do with the wireing harness? Is there gonna be a lot to splice and also what kind of ecu would be the best to go with?
Old Feb 27, 2007 | 07:39 AM
FlipHKD720's Avatar
Default RE: Wireing harness questions
I beleive both of those ECUs are OBD1 so you should just be able to plug and play. Just make sure when you get the z6 it comes with the ECU exactly for that motor and you should be able to get under the dash, unplug one and plug the new one in.
Old Feb 27, 2007 | 09:04 AM
i wasnt able to get the ecu for that motor because i bought the motor from a junkyard and someone already had stole it off of the car. So would i be able to buy one from a car the same year and would that work?Also will the ecu have to come from a 5speed car or does that matter?
Old Feb 27, 2007 | 09:35 AM
FlipHKD720's Avatar
yeah the manual vs. automatic really matters, you definately need to watch that. I Googled D16z6 and i thnk you have a P28 ECU, so i imagine if you just get a stock P28 ECU off Ebay you should be good to plug n play. Again, just make sure its for a 5 speed. You SHOULD be able to do that, i dont see why not.
Old Feb 27, 2007 | 09:46 AM
I remember seeing a black n green box under the hood that said P28 on it but i did not keep thatcause i didnt know what it was and also it was a automatic so i didnt know if would have done me any good. you should see this motor it runs fine all i have to do is get some sensors and a few other things and all i paid for it was $150. But im gonna build it up before i stick in into my 91 CRX Si
Old Feb 27, 2007 | 11:19 PM
b8teen's Avatar
91 si motor is obd 0, not obd1. z6 is a obd1
Old Feb 27, 2007 | 11:56 PM
so i have 2 get ob o to ob1 adapter and what bout the ecu then?
Old Feb 28, 2007 | 07:44 AM
FlipHKD720's Avatar
yeah, you should just be able to get an OBD0 to OBD1conversion harness that is just plug and play. As for the ECU, go to junkyard or Ebay and search for OEM P28 ECU. Seems like that should work for you.
Old Feb 28, 2007 | 08:34 AM
yea i was looking into that stuff last nite and like you said i should just b able to get the adapter and be able to just plug in and play but i do need to find a ecu now though
Old Feb 28, 2007 | 09:21 AM
FlipHKD720's Avatar
ebay is your best bet
