wont start
wont start
so i have a 90 civic hb.drove fine everyday,i had to get surgery on my sholder so i couldn't dive if for about a month.so finally im able to use my arm and wanting to drive my car.try to start it and nothing k so it's the battery right.i got another battery and my car then want's to start but doesn't and all my lights,brake lights,dome light dont turn on the only thing that does work r my hazards.please help i checked all the wires that hook up to the battery and there all connected
-Check for blown fuses under the dash and hood.
-Check for spark at the plugs and listen for priming of the fuel pump.
-Pull the carpet back from the ECU under the front passenger dash and check for trouble codes blinking from the LED.
checked all fuses all good,i have no spark when i connected the battery,dont here anything when i conect.i have a p30 it doesn't have any blinking LED.
Oh, you have an OBDI P30 ECU. Then jump the service connector and watch the blinking code(s) from the CEL.
Click Spark link in my signature. This tells you how to check for spark at the plugs.
Turn the key to ON(II). Do you hear the low humming sound of the fuel pump priming for 2 seconds?
hey i checked the red and yellow little boxs and they were blown,i replaced them and now i got power back to my lights and everything but still wont start,thanks for that one
you are still lacking power9(+-12v) from somewhere.
recheck all your fuses under hood and dash..
have you tried to jump the starter...
put car in nuetral first then turn key to the on position and on the starter there is 2 wires going to it...take a good piece of wire and touch both pieces on the starter together to start engine..
