HondaCivicForum.com
-   ED-EF Swaps (https://www.hondacivicforum.com/forum/ed-ef-swaps-35/)
-   -   89 Hatchback DX Need an Engine (https://www.hondacivicforum.com/forum/ed-ef-swaps-35/89-hatchback-dx-need-engine-36098/)
markwilson 01-15-2007 12:14 AM
I bought a 89 Hatchback DX for five hundred bucks, High miles and the engine isnt in great shape at all.
Its got the 16 valve 1.5 litre SOHC engine
What is a really easy swap for it? What kind of replacement engines can I look for? besides the same one of course
I would like something with an easy swap, Im not up for the big modifications.
And maybe a little more hp like a DOHC or something
What do you think? Help Me
Powermidget 01-15-2007 10:56 AM
RE: 89 Hatchback DX Need an Engine
B16, B18a or c area all relatively easy if you buy the swap complete...it depends on how much you want to spend...
markwilson 01-15-2007 11:58 PM
Well basically i want to spend as little as possible. I am a newby as well so I dont really know the codes, what cars are those from?
Thanks for the reply though
finalimpact 01-16-2007 01:32 AM
d16a6 found in the 88-91 crx si/ civic si/ civic ex. its a direct bolt in for you car assuming you use your current intake and exh manifolds. its one of the most popular sohc engines due to the steel main girddle caps and is well known to make more power than factory ratings in stock form.
civtec00 01-18-2007 06:37 PM
if you are doing a d16a6 swap you will have to get the harness the motor came out of(or modify your harness),because your stock motor is the dual point injection. if you do a d series vtec swap you will need the harness, and cumputer.
d16z6 - 92-95 civic vtec
d16y8 - 96-00 civic vtec
if you want to do a b series swap you will need new motor mounts, harness, computer, axles, etc.
Powermidget 01-22-2007 11:06 AM
B18 a1 is going to be pretty cheap and an easy install. That is an integra ls motor...not as high hp as the gen 1B16 (JDM CRX Sir)...but it has good torque and will be great if you plan on boosting...
markwilson 03-13-2008 09:36 AM
Oh man, get a non VTEC DOHC ZC engine, i did the swap, direct bolt-in some wiring changes but not too bad
