'91 Civic dx engine swap
Hi, i realize this has probably been asked alot before, but here goes.
I have a '91 Civic dx, with the stock 1500cc engine.
And im looking to swap it out, either for a b16 or b18 from a gsr.
what is easiest as far as engine mounts go? are either direct fit? or atleast fit with adaptors? (i am able to weld new mounts in if needed, but would rather not if i can get away with it)
Also my transmission is going so im thinking to swap one from the donor car i get the engine out of. will there be complications with that at all?
and as far as wiring/ecu.. what has to be done? or would it be easier to pull the harness and ecu from the donor.
Thanks for any help i can get.
for a b series you would need new mounts, shift linkage, integra axles, halfshaft, 90-93 integra throttle cable, a bseries tranny, computer, and you would have to convert you dual pint dx to multi port fuel injection(4 injectors instead of 2). the b16 and gsr motor will both bolt in the same
chbulldogs11@msn.com
May 27, 2011 09:05 PM
skibum853
Nov 18, 2007 09:40 AM
badboy4life
Sep 1, 2007 08:28 AM
silvr63vet
Dec 4, 2006 03:55 PM
