91 si with b16a
just wondering what radiator i should use to eliminate the lean
ummmmmmm what
that question or statement makes no sense as is. Would you care to elaborate just a little bit? |
sorry i bought the car with an obd0 b16a, but it had a 92+ radiator, i just need a stock ef radiator apparently.
No. What car do you have?
We have already established you have the B16a and that you have a 92-00 Half rad in there. I deal with radiators all day pretty much so lets find what you need. |
i have a 91 honda civic si hatch
Got it. Go for the EF rad then. That will be fine for you.
thanks
i would use a 90-93 integra radiator. it bolts in the stock location, and has the bigger hose ports for the b series. if you want the radiator to be hidden, or for more header clearance, or turbo clearance use a vw scirocco radiator. it fits inside the radiator support, and has the bigger hose ports also for the b series. you would need an inline radiator cap adapter for the scirocco radiator though.
I need a radiator for my 95 Si. What's the best place to buy ?
I would say the company I work for, but I am biased.
