B16A into DX
ok so how do you wire the harness together? the b16 has a complete uncut harness on it and the vehicle is a DX hatchback. what needs to be done to make the wiring work???
RE: B16A into DX
anyone?
RE: B16A into DX
Well I just Finished doing a ZC Swap Into my Dx. I'm assuming the B16A has MPFI. If so you will have to add wires for the injectors and probably get an ecu. Anyway I couldnt explain it now so go to the Do-it-yourself and you can probably find instructions. I found some sweet instructions for my ZC wiring it was really easy to follow so just look around.
RE: B16A into DX
thats the thing i can find the info for a zc or for an si sohc swap but nuthin on the b16 swap and yes it has mpfi on the b16 and it comes with an ecu i just need to know what wires im going to need to mess with and if i need any other harnesses besides my dx and b16 harness.
RE: B16A into DX
there oughta be an adaption...or a different wiring harness i was reading somewhere(im trying to do a b16 swap into a 91' CRX) that u can buy a complete wiring harness so you only have 2 cut like 4 wires to make it go together.....if i find tha site i'll send it 2 u
