b18c motor swap to 89 hatch
ok to start off i am tj and i have an 89 hatchback civic si that i am looking to put a b18c motor in. i have looked all around the forums and i believe this is the best route for me to take. i have some experience in mechanic work but i really havent ever dropped a motor in a car before. should i have this professionally done or not. i have also read on some forums that if i use this motor that i will need to cut into the firewall so that the intake fits. my car is a si model with the multiport fuel injection, so am i really gona have to cut into the firewall and could i use the stock si intake with the b18c ecu or is it a different intake all together.
i found the swap and i believe the kit has everything i need but the mounts and a cable/hydrulic conversion kit. how much will these two things run me.
also the motor swap kit is around $4K, does this seem right or am i about to be ripped off.
how much should this complete swap run me when everything is done.
Thanks for the help,
TJ
TJ
93b18civic
Feb 14, 2011 01:57 PM
roc_sky
Feb 26, 2006 07:45 PM
cdiddym
Dec 1, 2005 07:11 PM
drtalon
18
Aug 19, 2005 12:21 PM
