F22 Swap
This guy I met is selling a 92 Prelude for $200 to $300 dollars. It has a F22 with a 5 speed manual trans. The front end is wrecked and the battery blew up. The motor seems to be intact no damage. I was thinking about parting out the car and swaping the engine to my 90 hatch? What do you guys think?
RE: F22 Swap
I want to keep the F22 engine and put an H22 v-tec head. The reason I want to keep the F22 engine is it comes with iron sleeves. Any other suggestions would be very helpful and appreciated. What do I need to complete the swap? The engine is coming out of a 92 Prelude. Is there a company that sells a kit for this? How much does it cost?
RE: F22 Swap
isnt the f22 SOHC and the H22 DOHC? if so your cant swap the heads. Typically you cant swap heads from one letter series motor to another letter series motor
RE: F22 Swap
How much does a H22 cost? How much can I sell the f22 for and where?
RE: F22 Swap
If I'm not mistaking F22 is DOHC just not v-tec and alot less horeses then it's more known brothers H23 H22.
check this out http://home.comcast.net/~ndd3d/TurboInstall.pdf crazy f22 alot of work |
RE: F22 Swap
F22 Is a Sohc motor, I used to have a 91 accord. However, the JDM F22 is DOHC I believe. Check out cb7tuner.com they have a ton of info on the f22 engine.
RE: F22 Swap
ORIGINAL: mercfwd check this out http://home.comcast.net/~ndd3d/TurboInstall.pdf crazy f22 alot of work And oh yes i'm an F22A, F22B H22, H23, and F23 expert. |
RE: F22 Swap
my fualt I was reading alot on the JDM f22 at the time, yeah the usdm f22 is sohc, sorry.
RE: F22 Swap
you can swap a H22 head onto the sohc F series.
