I wanna do motor swap!! Final decision for hp. WHAT MOTOR??
Hey i wanna do a engine swap on my 89 honda civic hb dx, cuz its only pushing what like 90hp tops. What motor is the best for daily driving but still has punch. Id like a easy swap no fabs or anything. I know there still will be some. But dont got alot of cash. Was thinking of doing a Zc and just fixing the wire harness problem. Let me know thanks. ........ Post engine and hp and what needs 2 be done to make it work. Thanks
[Deleted]
[Deleted by Admins]
RE: I wanna do motor swap!! Final decision for hp. WHAT MOTOR??
well i know u can get a zc for around 700 bucks and im pretty sure you just have to convert the wire harness
[Deleted]
[Deleted by Admins]
ive fantasized of having enough money to MAKE a 4g63 motor fit in my civic. id basically smoke any honda owner ragerdless of what they have done. hands down the 4g63 is the best motor ever made
(Spoken like a true former DSM owner):D |
id say go with the b16
[Deleted]
[Deleted by Admins]
RE: Hey, I have an 89' Civic
Whats Up??, i dont know where to find the Hp on my engine but if its good enuff ill swap yah, where do you live??
what motor u wanna kno stats for?
you swap these motors in your car.
any d-series motor will fit in your car but your going to have to do some wiring and get ecu's and change a distributor if needed. D15B2 1493cc 4 cyl, 16valve SOHC 9.2:1 c.r 92 bhp @ 6000 Redline: 6800 rpm 89 lb-ft @ 4500 D16A6 1590cc 4 cyl, 16valve SOHC 9.1:1 c.r. 108 bhp @ 6000 Redline: 7100 rpm 100 lb-ft @ 5000 ZC D16A8 D16A9 1595cc 4 cyl, 16valve DOHC 9.1 c.r. 137 bhp @ 6800 Redline: 7200 rpm 108 lb-ft @ 5700 D16Y8 1590cc 4 cyl, 16valve SOHC VTEC-II 9.6:1 c.r. 127 bhp @ 6600 Redline: 7200 rpm 107 lb-ft @ 5500 D16Z6 1590cc 4 cyl, 16 valve SOHC VTEC 9.2:1 c.r. 125 bhp @ 6600 Redline: 7200 rpm 106 lb-ft @ 5200 but with b-series motor is where your gonna have a hard time but its worth the sweat. also your going to have to change the motor mounts and also do some wiring and probably change a distributor to obd1 or 2. and ecu B16A1 1595cc 4 cyl, 16valve DOHC VTEC 10.4:1c.r. 160 bhp @ 7600 Redline: 8200 rpm 111 lb-ft @ 7000 B18B 1834cc 4 cyl, 16valve DOHC 9.2:1 c.r. 130 bhp @ 6000 Redline: 6500 rpm 121 lb-ft @ 5000 B18B1 1834cc 4 cyl, 16 valve DOHC 9.2:1 c.r. 140 hp @ 6300 Redline: 6800 rpm 121 lb-ft @ 5200 B18C1 1797cc 4 cyl, 16valve DOHC VTEC 10.0:1 c.r. Dual stage intake 170 bhp @ 7600 Redline: 8200 rpm 128lbs-ft @ 6200 B16A4 1595cc 4 cyl, 16valve DOHC VTEC 10.4:1 c.r. 170 bhp @ 7800 Redline: 8200 rpm 16Nm @ 7300 B18C 98 Spec-R 1797cc 4 cyl, 16valve DOHC VTEC 10.0:1 c.r 210 bhp @ 8100 Redline: 8900 rpm 18.5Nm @ 7500 B16B 98 Spec-R 1595cc 4 cyl, 16valve DOHC VTEC 10.4:1 c.r. 185 bhp @ 8200 Redline: 9000 rpm 16.3Nm @ 7600 B20 ???? 4 cyl, 16valve DOHC non-VTEC ????? ??????? ???????????? now if you wanna go butt wild get a h22 lol |
