mini me help
ok so i got a 91 si and i wanna do a mini me. will my valve cover intake manifold and all that work. i know my dizzy wont unless i do some fab work. also if u use a p28 ecu and get the conversion harness will my injectors and sizzy work or do i need to still put on the resistor box and get a obd1 dizzy. thanks for the help
RE: mini me help
what motor are you using? d16z6, or the d16y8? the intake manifold from your d16a6 motor will fit on both motors but the d16y8 doesnt have the hole for the intake air temp sensor on the manifold, im not sure about the valve cover because i think that the d16a6 plugs are on the other side of the cover, than the d16z6, d16y8
RE: mini me help
your valve cover will not work. and with an obd1 conversion....you can still use yoru factory injectors assuming you leave the resistor box in place. as for the dizzy you will have to get an obd1 dizzy.
