motor mounts
im about to doa ls swap into my 90 hatch dx, but the thing is i only have the engineside mount and the tranny mount,the real question is what mount can i use for the rear tranny?????
RE: motor mounts
are we talking stock mounts here? if so those wont work. you need to get your hands on swap mounts. they can be found on ebay for 100-300 depending on the brand. there listed as b-series swap mounts
RE: motor mounts
if you dont alreadyhave swap mounts you will need them andyou should knowthe innovative mountswill likely requireyou get asmaller pully kit....the mounts are great i have them and love them super stiff...but if you are considering them you should know one of the stockls pulleys will likely rub...supposedly not an issue if you use the hasport mounts
RE: motor mounts
the motor mounts that i have are both ENJO precision for the ls swap but the problem is the rear tranny mount because i dont have it, so is there any other mount that i can use to take its place
RE: motor mounts
youll have to use the enjoy rear mount........all mount kits are made differently and place the engine in a certaint location. although you might get away with some other mount i highly doubt it. you can get cheap ebay speacials for like 150 shipped.
RE: motor mounts
thanks 4 the help:D
