Motor Swap
I bought a 90 CRX DX with a 1.5 L non vtech motor about a year ago. About 4 months ago it began smoking and who knows what else, basically shut down and has set since then. I purchased a motor from a 2000 Civic DX, 1.6L SOHC Vtech. I would like to know the basics that may be necessary to perform this swap. If it is compatible or not. I know that I have to purchase an ECU and wiring harness since mine was not Vtech. The motor came with tranny so that is not an issue. I would like to make this a super car, but it just isn't the time. I want to do a basic swap to get the car running and worry about the upgrades later.
RE: Motor Swap
another d-series v-tec motor swap gotta love em. anyways yes your going to need to the wire harness and the ecu plus some converting to do like changing the wiring to multi fuel and od2 unless you use a obd0.
RE: Motor Swap
and youll keep your stock tranny.
RE: Motor Swap
The tranny off of the 2000 motor won't work with the CRX?
RE: Motor Swap
no im pretty sure there hydrolic and you need a cable.
