HondaCivicForum.com
-   ED-EF Swaps (https://www.hondacivicforum.com/forum/ed-ef-swaps-35/)
-   -   Motor swap b16 or ZC or H23 (https://www.hondacivicforum.com/forum/ed-ef-swaps-35/motor-swap-b16-zc-h23-17472/)
91CivicMan Feb 22, 2006 08:58 PM
I have a 1991 honda civic sedan with a y7 motor and im wanting to upgrade should i go with the h23, b16, ZC? Could ya let me know the pros and cons
yorky Feb 23, 2006 05:41 AM
RE: Motor swap b16 or ZC or H23
i got an 88 sedan and i want a zc but they hardly make any performance parts for that engine.b16 s are way more powerful but require more mods to fit.i bought the honda engine swap guide so i can do alot of research.
usmc2b2004 Feb 23, 2006 08:14 AM
Its hard to find an OBD0 b16 you could put a OBDI with alot of wiring but its possible.
91CivicMan Feb 23, 2006 08:54 AM
Would the H23 be to big to fit in that car or wut bout a ls motor???
ef4life Feb 23, 2006 09:55 PM
an h series is a big project that involves a lot of cutting and welding and that is for a bolt in mount kit.
b series a a relatively easy swap, and rewireing to obd 1 is not too hard, its just a matter of buying a conversion harness from someone like www.jkobd.com www.boomslang.us or www.rywire.com
Kappa22 Feb 24, 2006 01:59 AM
It doesn't necessarily involve a LOT of cutting, but it does involve some... at least for an H22. I have yet to do an H23.
The SIR-I B16A is a 4G motor, so you wouldn't have a problem there.
And there's plenty of aftermarket support for ZC motors... All they are are D-series'.
yorky Feb 24, 2006 05:13 AM
dude what are you talking about? ive never seen any zc parts.you know a site post it.
finalimpact Feb 24, 2006 12:09 PM
hahaha damn zc parts are evewhere if you know what to look for. crower/delta offers cams, bottom end parts are compatable with almost all sohc 1.6 bottom ends, you can find everything for a zc that you can find for a sohc 1.6. you will however never find parts listed as "zc" parts. mix and match and you can build your zc.
yorky Feb 24, 2006 03:27 PM
what types of engines share these parts.this is a deciding factor of which engine i wanna get.i want the zc becuuse its cheap and easy to install ,but the b16 is way more powerful and has tons of aftermarket support.i want to swap myself because labor is just too expensive.
ef4life Feb 24, 2006 05:14 PM
from my understanding, the zc uses the same rods as a d16, i believe the pistons might be different though
