Need help on gsr swap!!!!!!!!!!!!!!!!!!!!!!!!
i got a 1990 honda civic dx hb, and just got my 98 gsr motor back from the shop and now i need help on what tranny i should use (which i want to keep my cable clutch)and how i go about connecting the engine harness....
thanks hydro |
1 Attachment(s)
first you have dual point right? you will need to rewire the ecu to covert your car's wiring from 2 fuel injectors(stock on dx) to 4 fuel injectors(mpfi)
Attachment 16714 |
are you keeping it obd0? if so you need obd0 injectors, 90-91 integra injectors will work, make it multi port, run the vtec wires, use a pr3, or pw0 computer(if you are staying
obd0). any b series cable tranny will work just get the clutch for the tranny you use. (90-91 b series is different than 92-93). |
Originally Posted by civtec00
(Post 717620)
