tps sensor wiring
i have a question. i did a z6 swap in my ef and used a conversion harness to convert to obd 1. the only problem i have is with the tps sensor. the instructions said to swap the two outer wires on the sensor plug to make it work right. i was just wondering what colors and in what order are the three stock tps wires because i think i might have them switched around in the wrong order, and if they are in the wrong order would i need a new tps sensor because it might be damaged from the reversed wiring. thanks a lot everyone
right now i run the car without it plugged in, it runs fine without it except for the CEL, but with it plugged the idle goes up and down
so the wires are the same colors, now i need to know what order to put them in like from left to right. i have the order of them mixed up so i don't know which wire goes were.
