what swap for a 91 si
i was wanting to do an engine swap for my 91 si but i need it to pass smog cuz i live in cali. what would be the best swap for around 1500. i could get a b16 1st gen complete swap for 800 but it wont smog in cali. or should i just rebuild my d16 and turbo?
RE: what swap for a 91 si
drop a vtec head on there and go turbo...or find someone that can hook u up on the smog and do that dohc swap...if you get a motor newer than your car in caliand have all the docs you can have a ref check out your car certify it badge itand be legal for smogwith the dohc swap...its a process thats not particularly cheap but it makes the swap legit
I have a 90 civic sedan dx 1.5lt lookin to put in a vtec i hear that you can just change the head and the Ecu can you help me i am srry this has nuttin to do with your question but i don't now how to post my own maybe you can help me with that also thank you
Dominic |
A head and ecu is all you should need (some new head studs wouldn't be a bad idea either oh and a hondata head gasket)...i believe the y8 head will fit your car but you should search the forum for more info...Its the head off the 93 and up civics you want to look for....i would also recommend looking into an oil line for your head to keep it lubed...ive dont have to much experience with the sohc vtec conversion but if you use the search fnc someone on here does....
having the ecu with the swap would be nice.......but that would require an obd1 conversion as well as a mpfi conversion. these 2 conversion would net you the best gains. however the mpfi conversion would net you an even better gain than the vtec headswap alone while running dpfi.
i thought the si was a mpfi.
ORIGINAL: 97civic707 i thought the si was a mpfi. so an obd1 conversion or...........use a pr3 ecu, have it chipped with a sohc vtec map and have the knock sensor option disabled. |
i have the whole setup for you in my garage. resealed b18 with reworked pistons, dc header, Tanabe stainless 3" exhaust, integra LS trans AND ECU. motor has a total of 98 grand on it and it was resealed with the pistons worked about 15,000 ago. all that for 2100 negotiable. Lemme know man!
