zc swap into a 88 4 door dx
hey, iwas wondering if anyone had any suggestions on a zc swap into my 4 door civic? like parts needed and wiring?
RE: zc swap into a 88 4 door dx
dohc or sohc zc? most likely your going after the dohc version so in that case. you must convert to mpfi as your dpfi manifold wont bolt up to the dohc zc head.
DOHC ZC, any 4G tranny, 88-89 Integra 5-spd ECU (PG7), injector resistor box from any MPFI Civic/Integra, old ECU plugs to pull pins from, surplus wire and looming.
for a tranny you must use the flywheel and clutch that is for that transmission. a si trans, si clutch, si flywheel. some years and models came with different sizes, and won't be compatible.
