95 Coupe Motor Swap Question
I wanna stick a 99 Si motor in my 95, this is my first attempt at this i understand i will need a harness some mounts and the motor of course anything else i should know or get, how long would this swap take and how hard is it..
where do you live? If you are in california, then smog will be an issue. if not, then you would be better off with a japanese motor. they start with a little more power, and around 30-50k miles, all for less money. As for parts, you will need motor, trans, ecu, axles, mounts, shift linkage, and you should change the timing belt, water pump, and clutch while the motor is out. also, budget in a little more money for little things like hose clamps, hoses, sensors, spark plugs, wires, oil ( for both motor and trans) and other things that will pop up. a bigger radiator is not necessary, but neither is DOHC VTEC. Riiiight.if your car is vtec already, then a lot of work is done for you. the wiring is the hardest part. if you know anyone who is familiar with car audio wiring, enlist their help. All in all, if it goes smoothly, it can be done in a day. Good luck, and enjoy
topdogmancivic92
Aug 28, 2006 09:12 PM
dalifts
ED-EF Swaps
Apr 16, 2005 01:11 PM
