EG Swaps 1992-1995 Civics
B series hybrid swap!!!!
Old Apr 19, 2008 | 12:34 PM
fast95hatch's Avatar
Default B series hybrid swap!!!!
i have a 95 civic coupe...im building a Ls Vtec for it...it has a b18a1 block, b16a head, b16 tranny...i need to know which L bracket to use for the rear and which front tranny bracket to use...do i use 94-01 integra brakets or can i use 99-00 civic si brackets or do i use the 90-93 integra brackets??? does it matter which brackets i use if i swapped out to use a gsr tranny, or r all b series brackets the same???
Old Apr 19, 2008 | 04:26 PM
sacicons's Avatar
Default RE: B series hybrid swap!!!!
94-01 integra, except the one that mounts the ac compressor, thats del sol/si. as long as its hydro/hydro, the tranny mounts are the same for b series.
Old Apr 20, 2008 | 08:43 AM
yea i thought that the tranny brackets were the same but the 99-00 civic si tranny brackets have a different part number than the 94-01 integra, so that made me have seconds thoughts.
Old Apr 20, 2008 | 09:29 AM
sacicons's Avatar
really? ive swapped mine around a few times and never noticed a difference. never done a side by side comparo though. but i have swapped teg/b16 trannys back and forth without having to change mounts. damn, its been too long since i did my swap to remember what mounts i ordered. ill do some research and get back to you.
Old Apr 20, 2008 | 09:50 AM
sacicons's Avatar
it seems to me that all of them for a 92-95 should come from the teg, except the one for your AC, since the teg ac pump has a different bolt pattern. the 99-00 si pump is the same as the d series. 96-00 use the si mounts.
Old Apr 23, 2008 | 04:19 PM
thanks for researching it for me...i appreciate it...
but im still wondering on wut injector to use with my setup...i was gonna go with the rc 310cc injector...but should i go with peak and hold or saturated??...if i go peak and hold, then will i need a resister box??...im gettin my p28 ecu chipped, so by me having it chipped, will it be ok to run peak and hold without using a resistor box?
Old Apr 23, 2008 | 05:02 PM
sacicons's Avatar
go saturated, and screw the chip. get a Hondata and get it fully tuned, on a Dynapack if possible. it will run and drive better than a generic chip. are you still using the stock fuel pump?
Old Apr 24, 2008 | 12:16 PM
ima go with a walbro fuel pump 255lph
99silverSI
Apr 6, 2008 01:49 PM
topdogmancivic92
Aug 28, 2006 09:12 PM
S240161
Nov 3, 2005 08:35 PM
00exinfl
EK Swaps
Mar 28, 2005 10:29 PM
