EG Swaps 1992-1995 Civics
b18c1 swap
Old May 6, 2006 | 01:47 PM
roblinxs011087's Avatar
Default b18c1 swap
ok i'm fairly new to the forum and i have a 94 civc w d15b7 manual tranny. i went to the junkyard to look for a mini me head and ended up finding a b18c1 from an integra. since i'm only cost 500 bucks i just need to find out some things. 1. what would i need besides the axles and ecu?? 2. would i need new engine mounts? i'd just need a list of things i would need to look for to get a total amount for the swap, or would i be better of w/ a mini me? any help??
Old May 6, 2006 | 01:58 PM
AgentofDarkness's Avatar
Default RE: b18c1 swap
$500 is damn cheap for a GSR, i would jump all over it. You will need the engine, transmission, ECU, axles, wiring harness and one? motor mount. Also, your going to want to install a new water pump, timing belt, and clutch just to be safe.
Old May 6, 2006 | 02:14 PM
mentaldis0rder's Avatar
shift linkage.. i have Avid shift linkage if you want.. this is for 92-00 civic.. brand new never used cuz i crashed my civic.. bought off of ebay store for 125..send me a PM if you are interested... ill cut you a deal and take a loss.. this is the only part that i had for my GSR swap that i couldnt get a refund on it.. www.rywire.com for wiring harness
Old May 6, 2006 | 06:08 PM
so for a swap like this would it be better to go na or forced, if the numbers dont' improve too much i'd prefer to go na but any suggestions would help
Old May 6, 2006 | 07:37 PM
I'd go turbo. Since you are getting the engine for so cheap, i would rebuild the engine so you can run more boost. Since the engine has a small displacement, there is a limit to how much power you can make. When going N/A, i think that there really isn't a replacement for displacement.
Old May 6, 2006 | 09:56 PM
but then again i havent seen the condition of the motor. if it's in bad shape i think i might need to bore it out but that's when i get lost in the piston diameters. i found a package assembled by eagle but i donno if its the right one http://store.summitracing.com/partde...5&autoview=sku so would u think this would be the way to go??
Old May 6, 2006 | 11:05 PM
If that is a stroker it, which i think it is, then it is prolly not the best for FI. That stroker is prolly gonna give you a higher compression ratio. This will give you more power right off the bat the but the higher compression ratio will limit what you can do forced induction wise. If you want to go NA, which is a good idea if you want some power but don't want to spend a lot of money, then this is not a bad idea. If you want to go with a turbo the best idea would be to go low compression and bore the cylinders to 85mm (this will give you a 2.0L displacement i think). Then you can run a good amount of boost (10+) and make a really good amount of horsepower. It really depends on if you are gonna go N/A or FI.
Ratboyz
EK Swaps
Aug 13, 2007 03:59 PM
mentaldis0rder
EK Swaps
Apr 1, 2006 09:45 PM
mentaldis0rder
EK Swaps
Mar 17, 2006 10:21 PM
creative626
Mar 13, 2006 01:02 PM
Splurbyburble
May 3, 2005 05:10 PM
