Easiest Swap
Hey guys as some may know i just completed a Z6 build that i was happy with. Now i have a new project. I want to do a swap but want to know the easiest swap and best bang for buck. Going to turbo whatever swap i do. What do you guys feel like the most pain free swap is in 92-95 Civic EX. Thanks in advance.
RE: Easiest Swap
I would say top 2 canadates would be the LS or the B16
RE: Easiest Swap
For the b16a2 what all is needed for a complete swap into the 95 EX? Can anyone give me a list of exactly everything i need. will a p28 ecu work. The reason i ask is i have 2 already chipped with uberdata. Im new to the swaps been messing with the d-series for the last 2 years and have finally finished the project now i want to move to something else. Also does anyone know of a DIY or Walthrough for this swap. Thanks guys.
RE: Easiest Swap
a p28 can be chipped to work with the B16. youll need the engine with all the accessories (intake manifold, alternator, exhaust manifold, etc etc) transmission (hydro) ECU, axles, mounts (si, DOHC Del Sol or integra) shift linkage, and some patience to do the wiring. its only about four or five wires, but it can be a big headache. and install a new timing belt, water pump, timing belt pulleys, clutch, and the kind of things that might be worn out.
