engines
i was just wonderin Will a DOHC ZC j-spec engine fit in a civic between 1992 and 1995.
RE: engines
There are two different black top DOHC ZC's: The most common is the yellow plug version (straight drop-in for 4G's, 130 hp, 108 tq), and then there is the harder-to-find gray plug version (140 hp, 109 tq) that will drop right into a 5G. Good luck finding one though.
RE: engines
So yes it will you just need to purchase the proper mounts, last i checked it was around 1k for the mount from where i am in MD, and i can think of alot of bolt ons i could purchase for my sohc d16 motor..
RE: engines
im pickin up the engine this summer i was offered it for $1500cnd it has AEM cam gears, crane cams and a 2 peice header.
RE: engines
Sweet deal. But a mount kit should only run you around $300-400 USD...
RE: engines
i was gonna say go with a b16 but if its semi cuilt, sounds like a good deal.
RE: engines
been doin some reaserch on the net. I havn't been able to find any ZC Dohc swaps into a 5g civic. Seems like too much of a struggle to try so when i get it i might just sell it and go for a b16
RE: engines
b16 is more expensive than a zc by far
RE: engines
Not actually much more than a gray-plug ZC. Those are helza rare.
