h23 in EG
I'm considering swapping in an h23. I found a 94 si that was hit on the side. Hes asking 600 and the motor runs good. I know i need mounts but since i have a complete car will i need any wiring harnesses or would it be better to take it right off the si? And I was thinking about using the the brakes too but i'm not sure if they will fit or not. Any info would help thanks.
RE: h23 in EG
take EVERYTHING off the si. and keep it around while doing your swap, if you can, because you may need something.
as for as the brake swap, that's a good question. i've seen civics with NSX brake swaps, so anything is possible. |
