Shift linkage/Motor mounts
I have a eg 92 manual d15b7 now.I am putting the b18b1 into it I have 2 questions I have b18b1 mounts that are from an automatic ls.Do I need to get manual b18b1 mounts for the (manual b18b1) to bolt up in my eg. I also hear I need a shift linkage which civic or were can I get 1 at so the b18b1 will work in my 92 civic.Thanks
RE: Shift linkage/Motor mounts
I am pretty sure you need the linkage from a DA integra for that swap. as for the motor mounts i dunno i would assume they would work, but then again i also assumed that i wouldn't have to replace a motor mount when swapping in a D15B but i will have to.
What is a Da integra Is that the car the tranny came out of?
no the B1 came out of the 94-01 integra, but if i recall properly it calls for linkage from a DA(90-93), but i think you can use the linkage from a 94-01 as well. my brain is on overload right now from work so i can't remember 100%
I found a 96 acura integra ls manual tranny at one of them you pull it yourself junkyards.I already have the 2000 b18b1 engine and all the stuff but its automatic tranny,So I am going to get the flywheel,clutch,tranny,axles,starter,out of the 96 integra manual tranny.I was just wondering what else I need to get off 96 ls to do my swap any while I am there if I need the mounts and shift linkage might as well pick them up.
u might as well get the mounts off the dc...and also dont forget the slave cylinder(if it isnt already on the tranny)..and also if i were u id replace the mounts to near new mounts
you are gonna need to get the manuel tranny b18 mount the other 2 should bolt right in. also use the integra shift linkage
I will i'll grab that back tranny mount and the shift linkage from the car also Thanks.
