Swap Suggestions
Well next weekend (dec 9-11 hopefully) I will be swapping a b16a2 into a 93 dx coupeThis is my first swap and I was just wondering if anyways had any suggestions on how to make it go as smoothly as possible, seeing as it is quite essential that I have it done over the weekend. I also want to make sure that I have everything there and available, so I am guessing that i will need axles to go along with the swap, anything else? Thanks
replace the water pump and timing belt before you install the motor, it sucks to have to replace them once its in. same with the clutch, but the pump and belt are more urgent. have new axles and a hundred bucks or more just waiting for hoses and clamps and bolts and stuff. get as much done on fri-sat while the honda dealerships are open, because you will need some parts from them too.
