EG Swaps 1992-1995 Civics
timing gear
Old Apr 3, 2010 | 12:48 PM
carter136's Avatar
Default timing gear
i have the d16z6 is it worth th trouble to put on adj. timing gear .any ideas for good bolt ons
Old Apr 3, 2010 | 02:06 PM
If you don't need to adjust the crank-cam timing then you don't need an adjustable cam gear. If you needed an adjustable cam gear, you would know already. So no, you don't need one.
Old Apr 3, 2010 | 04:51 PM
carter136's Avatar
thanks what about a small shot of nos i have a few bolt on parts is the d16 up to it
Old Apr 3, 2010 | 05:06 PM
Nitrous is a waste of money, you have to keep refilling the bottle when you run out. It costs about $40 to fill up a 10 lb bottle.
It costs more, but you're better off with a turbo. After initial parts and tune cost, assuming you buy quality parts and install/maintain them properly, you won't really have to spend any additional money to keep it working. Nitrous is cheaper up front, more expensive in the long run. Turbo is more expensive up front, and cheaper in the long run.
Juans_MX3
Apr 9, 2010 05:37 AM
andybuck711
Mar 3, 2010 07:14 PM
honda_dud
Jul 10, 2009 06:48 PM
chasemclemore
May 18, 2009 04:21 PM
MasterJT
May 18, 2008 05:37 PM
